This tool can help to the certain extent, but it is not offering 100% success to control an application running
on a distant machine. Use this tool "AS-IS" to achive experiences with your applications resource consumption behavior
and to make your work probably a bit convenient.
Short description:
The philosophy behind this solution is to help users which aiming to control an application running on the distant computer. The notification system uses desktop screenshots via E-mail.
This application offering a MEM [ Megabytes] and CPU [ % ] "mapping" tool which calculates the MEM and CPU consumption mean values from a list of discrete MEM and CPU registrated in every 1 sec values within the user defined intervals of "trigger time". The exported plot file's csv format is an easy-to-use alternative in statistical analyses.
The resource "mapping" process gives realistic peak-values, which can be useful to estimate, for the choosen process, optimal Filter-settings. If any of the criterias from the Filter fulfilled or according to the user defined time intervals duration, an e-mail notification will be sent to user's mailbox.
[ http://geomatika.mapcat.net/COMMON/Projects/process_notifier_v0.41.zip ] , 286 KB
