query data from a web service
4868
17
04-23-2015 02:56 AM
sundussabbah
Hello everybody, I'm trying to query some data from a service table I wrote:       var query = new Query();       query.outFields = [ " * " ];           query.returnGeometry = true;               var queryTask = new QueryTask("url");       queryTask.execute(query,showResults);       but the showResult is never executed , what is the reason ?? please help me
sundussabbah
Ok, thank you, I understand now
KushendraShah1
New Contributor III
Tom, is there way you can make spatial query on feature layer that return geometry spatially without returning attributes? Thanks
TomSellsted
MVP Regular Contributor
Kushendra,
Yes!  You specify an empty array for outFields and specify the query geometry.  Something like:
query.geometry = webMercatorUtils.webMercatorToGeographic(firstGraphic.geometry)
query.spatialRelationship = Query.SPATIAL_REL_TOUCHES;
query.outFields = [];
queryTask.execute(query);
Regards,
Tom
KushendraShah1
New Contributor III
Thanks Tom
TomSellsted
You are welcome Kushendra!
SatyanarayanaNarmala
New Contributor III
hi sundus
where am i going wrong here. kindly guide me
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Popup</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body, #map {
        padding: 0;
        margin: 0;
        height: 100%;
      /* Change color of icons to match bar chart and selection symbol */
      .esriPopup.dark div.titleButton,
      .esriPopup.dark div.titlePane .title,
      .esriPopup.dark div.actionsPane .action {
        color: #A4CE67;
      /* Additional customizations */
      .esriPopup.dark .esriPopupWrapper {
        border: none;
      .esriPopup .contentPane {
        text-align: left;
      .esriViewPopup .gallery {
        margin: 0 auto;
    </style>
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/layers/FeatureLayer",
        "esri/dijit/Search",
        "esri/tasks/QueryTask",
        "esri/tasks/query",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct", "dojo/on",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar",
        "dojo/domReady!"
      ], function(
        Map,
        Popup, PopupTemplate,
        FeatureLayer, Search,
        QueryTask, Query,
        SimpleFillSymbol, Color,
        domClass, domConstruct, on,
        Chart, theme
        //The popup is the default info window so you only need to create the popup and
        //assign it to the map if you want to change default properties. Here we are
        //noting that the specified title content should display in the header bar
        //and providing our own selection symbol for polygons.
        var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
        var popup = new Popup({
            fillSymbol: fill,
            titleInBody: false
        }, domConstruct.create("div"));
        //Add the dark theme which is customized further in the <style> tag at the top of this page
        domClass.add(popup.domNode, "lighter");
        map = new Map("map", {
          basemap: "satellite",
          center: [79.2, 18.10],
          zoom: 8,
          infoWindow: popup
        var template = new PopupTemplate({
          title: "TELANGANA PATTA APPLICANTS",
          description: "Application No: {application_no} <br> <br>DISTRICT: {district_name1} <br><br>MANDAL: {mandal_name1}<br><br> VILLAGE: {village_name1} <br><br>  OCCUPANT NAME: {name_of_the_occupant} <br><br>ADDRESS: {present_address} <br><br> Survey No.: {survey_no} <br><br> LAND EXTENT: {extent_of_land} <br>",
        var featureLayer = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/patta1/FeatureServer/0",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          infoTemplate: template
        map.addLayer(featureLayer);
        var featureLayer2 = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/patta1/FeatureServer/2",{
          outFields: ["*"]
        map.addLayer(featureLayer2);
        var featureLayer1 = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/patta1/FeatureServer/1",{
          outFields: ["*"]
        map.addLayer(featureLayer1);
    queryTask = new QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/patta1/FeatureServer/2");
    query.outFields = ["*"];
        function executeQueryTask(population) {
  //set query based on what user typed in for population;
alert(population);
  query.where = "mname = '" + population + "'";
  //execute query
function showResults(featureSet) {
  //remove all graphics on the maps graphics layer
  map.graphics.clear();
  //Performance enhancer - assign featureSet array to a single variable.
  var resultFeatures = featureSet.features;
  //Loop through each feature returned
  for (var i=0, il=resultFeatures.length; i<il; i++) {
    //Get the current feature from the featureSet.
    //Feature is a graphic
    var graphic = resultFeatures;
    graphic.setSymbol(symbol);
    //Set the infoTemplate.
    graphic.setInfoTemplate(infoTemplate);
    //Add graphic to the map graphics layer.
    map.graphics.add(graphic);
    </script>
  </head>
  <body class="claro">
  <form name="classic">
<select name="countries" size="4" onChange="updatecities(this.selectedIndex)" style="width: 150px">
<option selected>Select A DISTRICT</option>
<option value="1">ADILABAD</option>
<option value="2">KARIMNAGAR</option>
<option value="3">KHAMMAM</option>
<option value="4">MAHABUBNAGAR</option>
<option value="5">MEDAK</option>
<option value="6">NALGONDA</option>
<option value="7">NIZAMABAD</option>
<option value="8">RANGA REDDY</option>
<option value="9">WARANGAL</option>
<option value="10">HYDERABAD</option>
</select>
Mandals:
<select name="cities" size="4" style="width: 150px" onClick="executeQueryTask(this.options[this.options.selectedIndex].value);">  <!-- alert(this.options[this.options.selectedIndex].value) -->
</select>
</form>
<script type="text/javascript">
var countrieslist=document.classic.countries
var citieslist=document.classic.cities
var cities=new Array()
cities[0]=""
cities[1]=["ADILABAD ", "    ASIFABAD ", "    BAZARHATHNOOR ", "    BEJJUR ", "    BELA ", "    BELLAMPALLE ", "    BHAINSA ", "    BHEEMINI  ", " BOATH ", "    CHENNUR ", "    DAHEGAON ", "    DANDEPALLE ", "    DILAWARPUR ", "    GUDIHATHNUR ", "    ICHODA ", "    INDERAVELLY ", "    JAINAD ", "    JAINOOR ", "    JAIPUR ", "    JANNARAM ", "    KADDAMPEDDUR ", "    KAGAZ NAGAR ", "    KASIPET ", "    KERAMERI ", "    KHANPUR     ", "    KOTAPALLE ", "    KOUTHALA ", "    KUBEER ", "    KUNTALA ", "    LAXMANCHANDA    ", "    LOHESRA ", "    LUXETTIPET     ", "    MAMDA     ", "    MANCHERIAL ", "        MANDAMARRI ", "        MUDHOLE     ", "    NARNOOR ", "    NENNAL ", "    NERADIGONDA ", "    NIRMAL ", "    REBBANA ", "    SARANGAPUR ", "    SIRPUR (T) ", "    SIRPUR (U) ", "    TALAMADUGU ", "    TAMSI     ", "    TANDUR ", "    TANUR ", " TIRYANI  ", "    UTNUR     ", "    VEMANPALLE     ", "    WANKDI"]
cities[2]=["BEJJANKI", "BHEEMADEVARPALLE", "BOINPALLE", "CHANDURTHI", "CHIGURUMAMIDI", "CHOPPADANDI", "DHARMAPURI", "DHARMARAM", "ELKATHURTHI", "ELLANTHAKUNTA", "GAMBHIRAOPET", "GANGADHARA", "GOLLAPALLE", "HUSNABAD", "HUZURABAD", "IBRAHIMPATNAM", "JAGTIAL", "JAMMIKUNTA", "JULAPALLE", "KAMALAPUR", "KAMANPUR", "KARIMNAGAR", "KATARAM", "KATHLAPUR", "KESAVAPATNAM", "KODIMIAL", "KOHEDA", "KONARAOPETA", "KORATLA", "MAHADEVPUR", "MALHARRAO", "MALLAPUR", "MALLIAL", "MANAKONDUR", "MANTHANI", "MEDIPALLE", "METPALLE", "MUSTABAD", "MUTHARAM MAHADEVPUR", "MUTHARAM MANTHANI", "ODELA", "PEDDAPALLE", "PEGADAPALLE", "RAIKAL", "RAMADUGU", "RAMAGUNDAM", "SAIDAPUR", "SARANGAPUR", "SIRSILLA", "SRIRAMPUR", "SULTANABAD", "THIMMAPUR", "VEENAVANKA", "VELGATOOR", "VEMULAWADA", "YELLA REDDI PETA"]
cities[3]=["ASWAPURAM", "ASWARAOPETA", "BAYYARAM", "BHADRACHALAM", "BONAKAL", "BURGAMPADU", "CHANDRUGONDA", "CHERLA", "CHINTHAKANI", "DAMMAPETA", "DUMMUGUDEM", "ENKURU", "GARLA", "GUNDALA", "JULURPAD", "KALLURU", "KAMEPALLE", "KHAMMAM RURAL", "KHAMMAM URBAN", "KONIJERLA", "KOTHAGUDEM", "KUSUMANCHI", "MADHIRA", "MANUGURU", "MUDIGONDA", "MULAKALAPALLE", "NELAKONDAPALLE", "PALAWANCHA", "PENUBALLI", "PINAPAKA", "SATHUPALLE", "SINGARENI", "TEKULAPALLE", "THALLADA", "THIRUMALAYAPALEM", "VEMSOOR", "VENKATAPURAM", "WAZEED", "WYRA", "YELLANDU", "YERRUPALEM"]
cities[4]=["ACHAMPETA", "ADDAKAL", "AIZA", "ALAMPUR", "AMANGAL", "AMRABAD", "ATMAKUR", "BALANAGAR", "BALMOOR", "BHOOTHPUR", "BIJINAPALLE", "BOMRASPETA", "CHINNA CHINTA KUNTA", "DAMARAGIDDA", "DEVARKADARA", "DHANWADA", "DHARUR", "DOULATABAD", "FAROOQNAGAR", "GADWAL", "GHANPUR", "GHATTU", "GOPALPETA", "HANWADA", "ITIKYAL", "JADCHERLA", "KALAWAKURTHY", "KESHAMPETA", "KODAIR", "KOILKONDA", "KOLLAPUR", "KONDANGAL", "KONDURG", "KOSGI", "KOTHAKONTA", "KOTHUR", "LINGAL", "MADDUR", "MADGUL", "MAGANOOR", "MAHABUBNAGAR", "MAKTHAL", "MALADAKAL", "MANOPADU", "MIDJIL", "NAGAR KURNOOL", "NARAYANPET", "NARVA", "NAWABPET", "PANGAL", "PEBBAIR", "PEDDAKOTHAPALLE", "PEDDAMANDADI", "TADOOR", "TALAKONDAPALLE", "TELKAPALLE", "THIMMAJIPETA", "UPPUNUNTHALA", "UTKOOR", "VANGOOR", "VEEPANGANDLA", "VELDANDA", "WADDEPALLE", "WANAPARTHY"]
cities[5]=["ALLADURG", "ANDOLE", "CHEGUNTA", "CHINNAKODUR", "DOULTHABAD", "DUBBAK", "GAJWEL", "HATHNOORA", "JAGDEVPUR", "JHARASANGAM", "JINNARAM", "KALHER", "KANGTI", "KOHIR", "KONDAPAK", "KONDAPUR", "KOWDIPALLI", "KULCHARAM", "MANOOR", "MEDAK", "MIRDODDI", "MULUGU", "MUNIPALLE", "NANGNUR", "NARAYANKHED", "NARSAPUR", "NYALKAL", "PAPANNAPET", "PATANCHERU", "PULKAL", "RAIKODE", "RAMACHANDRAPURAM", "RAMAYAMPET", "REGODE", "SADASIVPET", "SANGAREDDY", "SHANKARAMPET(A)", "SHANKARAMPET(R)", "SHIVAMPET", "SIDDIPET", "TEKMAL", "TOOPRAN", "WARGAL", "YELDURTHI", "ZAHIRABAD"]
cities[6]=["ALAIR", "ANUMULA", "ATMAKUR  (S)", "ATMAKUR (M)", "BHUVANAGIRI", "BIBINAGAR", "BOMMALARAMARAM", "CHANDAM PET", "CHANDUR", "CHILKUR", "CHINTHA PALLE", "CHITYALA", "CHIVVEMLA", "CHOUTUPPAL", "DAMERACHERLA", "DEVARAKONDA", "GARIDE PALLE", "GUNDALA", "GUNDLA PALLE", "GURRAMPODE", "HUZURNAGAR", "JAJI REDDI GUDEM", "KANGAL", "KATTANGOOR", "KETHEPALLE", "KODAD", "M TURKAPALLE", "MARRI GUDA", "MATTAMPALLE", "MELLACHERVU", "MIRYALAGUDA", "MOTHEY", "MOTHKUR", "MUNAGALA", "MUNUGODE", "NADIGUDEM", "NAKREKAL", "NALGONDA", "NAMPALLE", "NARAYANAPUR", "NARKETPALLE", "NERED CHERLA", "NIDAMANUR", "NUTHANKAL", "PEDDA ADISERLAPALLE", "PEDDAVURA", "PENPAHAD", "POCHAMPALLE", "RAJAPET", "RAMANNAPETA", "SALIGOURARAM", "SURYAPET", "THIPPARTHI", "THIRUMALAGIRI", "THRIPURARAM", "THUNGA THURTHI", "VALIGONDA", "VEMULAPALLE", "YADAGIRIGUTTA"]
cities[7]=["ARMUR", "BALKONDA", "BANSWADA", "BHEEMGAL", "BHIKNUR", "BICHKUNDA", "BIRKOOR", "BODHAN", "DHARPALLE", "DICH PALLE", "DOMAKONDA", "GANDHARI", "JAKRANPALLE", "JUKKAL", "KAMAREDDY", "KAMMAR PALLE", "KOTGIRI", "LINGAMPET", "MACHAREDDY", "MADNUR", "MAKLOOR", "MORTAD", "NAGA REDDIPET", "NANDIPET", "NAVIPET", "NIZAM SAGAR", "NIZAMABAD", "NIZAMABAD (M)", "PITLAM", "RANJAL", "SADASIVANAGAR", "SIRKONDA", "TADWAI", "VARNI", "VELPUR", "YEDA PALLE", "YELLAREDDY"]
cities[8]=["BALANAGAR", "BANTARAM", "BASHEERABAD", "CHEVELLA", "DHARUR", "DOMA", "GANDEED", "GHATKESAR", "HAYATHNAGAR", "IBRAHIMPATAM", "IBRAHIMPATNAM", "KANDUKUR", "KEESARA", "KULKACHARLA", "MAHESWARAM", "MALKAJGIRI", "MANCHAL", "MARPALLE", "MEDCHAL", "MOINABAD", "MOMINPET", "NAWABPET", "PARGI", "PEDDEMUL", "PUDUR", "QUTHBULLAPUR", "RAJENDRANAGAR", "SAROORNAGAR", "SERLINGAMPALLY", "SHABAD", "SHAMIRPET", "SHAMSHABAD", "SHANKARPALLE", "TANDUR", "UPPAL", "VIKARABAD", "YACHARAM", "YELAL"]
cities[9]=["ATMAKUR", "BACHANNAPETA", "BHUPALPALLE", "CHENNARAOPET", "CHERIYAL", "CHITYAL", "DEVARUPPULA", "DHARMASAGAR", "DORNAKAL", "DUGGONDI", "ETURNAGARAM", "GEESUGONDA", "GHANAPUR", "GHANPUR(stn)", "GOVINDARAOPET", "GUDUR", "HANAMKONDA", "HASANPARTHY", "JANGAON", "KESAMUDRAM", "KHANAPUR", "KODAKANDLA", "KOTHAGUDEM", "KURAVI", "LINGALA GHANPUR", "MADDUR", "MAHABUBABAD", "MANGAPET", "MARIPEDA", "MOGULLAPALLE", "MULUG", "NALLABELLY", "NARMETTA", "NARSAMPET", "NARSIMHULAPET", "NEKKONDA", "NELLIKUDUR", "PALAKURTHI", "PARKAL", "PARVATHAGIRI", "RAGHUNATHA PALLE", "RAIPARTHY", "REGONDA", "SANGEM", "TADVAI", "THORRUR", "VENKATAPUR", "WARANGAL", "WARDHANNAPET", "ZAFFERGADH"]
cities[10]=["HYDERABAD"]
function updatecities(selectedcitygroup){
    citieslist.options.length=0
    if (selectedcitygroup>0){
        for (i=0; i<cities[selectedcitygroup].length; i++)
            citieslist.options[citieslist.options.length]=new Option(cities[selectedcitygroup].split("|")[0], cities[selectedcitygroup].split("|")[1])
</script>
    <div id="map"></div>
  </body>
</html>
TomSellsted
Satyanarayana,
Can you be more specific about the problem you are having with your script?  What is it not doing?
Regards,
Tom
sundussabbah
what is the problem with the code??
I will help if I can
