retrieving the COM class factory for component with CLSID {D9B4FA40-D6D9-11D1-AA81-00C04FA33A15}failed due to the following error: 80040111
4657
9
06-22-2017 12:51 PM
JoseSanchez
Occasional Contributor III
Hello everyone,
I  wrote a web service a few months ago, and it was working fine. Then I decided to upgrade my workstation to ArcGIS Server 10.3 and it stopped working. So I uninstalled AcGIS Server 10.3 and I installed back ArcGIS Server 10.2 and the web service still does not work.
I am using ArcGIS 10.2 client and server on my workstation. IIS .Net Framework 3.5 and  ApplicationPool 2.0, VS 2010 or VS 2012. I also did tests with IIS .Net Framework 4.0 and Application Pool 4.0 and the error persists.
Please take a look to the zipped file attached to this post. It is a simplified version of the web service, it can be opened with  VS 2010 or VS 2012. The line that has the problem is this one: "CType(Activator.CreateInstance(factoryType), ESRI.ArcGIS.Geodatabase.IWorkspaceFactory)", it fails with an error message "retrieving the COM class factory for component with CLSID {D9B4FA40-D6D9-11D1-AA81-00C04FA33A15}failed due to the following error: 80040111."
Also I created a Console Application using the same code and it works fine.
HELP!!!!!
<WebMethod()> _
Public Function HelloWorld() As String
' For example, connectionFile = "C:\myData\Connection to Kona.sde".
'Public Function ArcSdeWorkspaceFromFile(ByVal connectionFile As String) As IWorkspace
Try
Dim connectionFile As String
Dim factoryType As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory")
Dim workspaceFactory As ESRI.ArcGIS.Geodatabase.IWorkspaceFactory = Nothing
Dim wsFactory As ESRI.ArcGIS.Geodatabase.IWorkspaceFactory = Nothing
' This is where I get the error message:
' Retrieving the COM class factory for component with CLSID {D9B4FA40-D6D9-11D1-AA81-00C04FA33A15}
' failed due to the following error: 80040111.
workspaceFactory = CType(Activator.CreateInstance(factoryType), ESRI.ArcGIS.Geodatabase.IWorkspaceFactory)
Catch ex As Exception
Console.WriteLine(ex.Message)
Return ex.Message
End Try
'End Sub
Return "Hello World"
End Function
sapnas
sapnas
Is your Enable 32-bit applications property in IIS app pool  set to True by any chance?
JoseSanchez
Where do you  set up this value in IIS?
JoseSanchez
Just checked, and the value is set to True.
sapnas
Set it to false
JoseSanchez
Hi Spana,
I set it to False and the line where it was failing does not fail anymore.
Now  I am getting an error message on the next line of the code:  workspaceFactory.OpenFromFile(connectionFile, 0)  with error message:
Error HRESULT E_FAIL has been returned from a call to a COM component.
connectionFile = "C:\SDEConn\SDEINSTANCE.sde"
Dim myIWorkspace As IWorkspace
myIWorkspace = workspaceFactory.OpenFromFile(connectionFile, 0)   ********* ERROR MESSAGE
JoseSanchez
Found it!!!  The IIS account IIS_IUSRS must be added to the folder where SDE Connection files are located in read only access. Otherwise the ASP.Net application can no read the folder.
sapnas
That is correct if the IIS authentication is Anonymous IIS_USRS should have access to that folder
JoseSanchez
Hello again,
the application was working fine last Friday but today I am getting the error message below in this line:
Error message:
Retrieving the COM class factory for component with CLSID {D9B4FA40-D6D9-11D1-AA81-00C04FA33A15} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
Any suggestions
JoseSanchez
Found it! I just removed and added two references: Esri.ArcGIs.Geodatabae and EsriArcGIS.Syste, and it works now.
