Version 1 of the Electric Utility Network Migration Tools are now available for download from this post.
The Electric Utility Network Migration Tools help you transform electric system data from a geometric network to a utility network using FME or ArcGIS Pro with the Data Interoperability Extension. It includes a workbench, assembly builder, a schema mapper, tools, sample data, and documentation.
The provided workbench, assembly builder, schema mapper, and sample source data are set up for a schema that is very similar to how an electric distribution system is typically represented as a geometric network. You will need to further configure the workbench, assembly builder, and schema mapper for your source data.
Please use this GeoNet discussion to ask questions and share your feedback.
