Apologies, I had a technical issue--reposting my initial questions below:
While I have not heard of any specific accomplishments on this myself, as a Solution
Engineer, I would like to understand more about your needs/requirements as a customer
for integrating GIS data into your PSS SINCAL simulation software.
More specifically:
Is your network data in a geometric network or have you moved to the utility
network?
Is the planning and analysis work focused on Transmission, Distribution, or both?
Are you accounting for behind-the-meter DER's, grid-scale DERs, or both?
Besides GIS, what other data are you integrating into PSS SINCAL (MDM, SCADA,
CRM etc.)?
Thank you for your response!
