Hi ArcGIS Utilities Team,
I have installed the Electric Utilities and extension and I did apply the Electric Asset Package without populating the test data so the domain feature classes contain no data.
I would like to make some changes but I am not sure whether it would cause any problems. Basically, i would like to be advised on what changes I can/cannot make to the Electric Utility Asset Package configuration after installation.
In case the following is not safe, does it mean i have to configure everything from scratch?
1. Can I safely append attribute domain values to what you have already defined?
2. Can I safely add additional SubTypes to the domain feature classes?
3. Can I safely add new fields to the structure and domain feature classes?
Thanks for technical assistance
