POST | Hello everyone,I created a raster with the Topo to Raster tool. for this I used layers of points and lines with eleva... by AntonioMoniz New Contributor III 0 3 | 0 | 3 | 1287 | |
POST | Using Pro it is possivle to create an elevation profile for a feature; however this can only be exported as an image.... by JamesGoodyear New Contributor 3 1 | 3 | 1 | 910 | |
POST | I have a raster showing the topography of an area. I need to add 0.1 m to an area of the raster. I have tried making... by ArranClarke New Contributor 0 7 | 0 | 7 | 1090 | |
POST | I have some GPS data with the elevation taken using the hybrid GEOID18. Can I covert the elevation values from GEOID1... by PatriciaCarbajales New Contributor 0 0 | 0 | 0 | 481 | |
POST | Hi i am completly new to this, i have set up a basic webscene , and now i want to add elevation profile to that map.b... by RahulSapkota New Contributor 0 0 | 0 | 0 | 492 | |
POST | I have two DEMs (geotif), one is of a larger area and the other of a smaller area located in the middle of the first ... by Anonymous User Not applicable 0 0 | 0 | 0 | 930 | |
POST | Hello!I am working on maybe an unusal project right now. I have downloaded a race route from my Strava account as a G... by JohnnyHarley New Contributor 0 1 | 0 | 1 | 857 | |
POST | Hi, I am currently editing a layer and in doing so I am losing the ‘z’ values of various features. I do have a TIN mo... by AntonelloRizzo_Naudi New Contributor 0 0 | 0 | 0 | 279 | |
POST | I have a USGSDEM file downloaded from NRCAN. It has a known geographic coordinate system (GCS_North_American_1983) so... by Myla-RaeBaldwin New Contributor II 0 3 | 0 | 3 | 2593 | |
POST | Hello,If you were to take a certain elevation threshold (contour line) and select all area ABOVE that line, you might... by CoreyChin New Contributor 0 2 | 0 | 2 | 793 | |
POST | I have created a Hillshade effect and would like to use the Contours tool on the 3D Analyst toolbar to show me the Co... by SLouq MVP Regular Contributor 0 2 | 0 | 2 | 293 | |
POST | Team,The default or first option for any raster re-sampling / re-projection geoprocessing tools is "nearest neighbor"... by JoelSholtes New Contributor 0 0 | 0 | 0 | 200 | |
POST | I have a Digital Elevation Model and polygon shapefile and I want to make an effect that polygons follow terrain stru... by SlobodanKomatina2 New Contributor II 0 2 | 0 | 2 | 810 | |
POST | Hi fellas,I have a line feature, also have a DEM, just want to extract the highest and lowest points of this line. I ... by Liliaaaaaa New Contributor III 0 6 | 0 | 6 | 1936 | |
POST | 0 | 2 | 358 |
