Is it possible to integrate geonetwork metadata to esri geoportal.
4930
8
01-15-2013 08:09 PM
SameerBajracharya
Dear all,
I am new to ESRI Geoportal Server can anyone help me for integrating geonetwork metadata to esri geoportal. Is there any tools to connect these two metadata management system. Thank you.
Regards,
sameer
WallaceBezerra
New Contributor II
You can configure a CSW connection to the Geonetwork catalogue. The url will be something like this: http://www.metadados.geo.ibge.gov.br/geonetwork/srv/br/csw?service=CSW&request=GetCapabilities&versi..., where you will change the domain portion and probably the localization of your instalation (/br/).
SameerBajracharya
I have install esri geoportal, configure database and everything is going well. can you give a bit detail on how to configure CSW connection to geonetwork. Thank you
sameer
WallaceBezerra
New Contributor II
sameer,
go to the Administration section go to Add-> Register resource on the network.
On the Register Resource, choose the CSW option on "Protocol Type".
Important: on the field Host Url you need to type the url of the CSW service with the GetCapabilities operation (like the one a linked on the previous post).
Here have a picture with an example. Hope this help.
SameerBajracharya
Dear wallace,
Thank you so much for your help, I successfully manage to harvest metadata using CSW but only few data are harvested. I tried in local geonetwork with 10 metadata and only 2 metadata are harvested. Is there any step missing. Thank you
Regards,
sameer
WallaceBezerra
New Contributor II
hi again!
Probably some of your metadata records are not passing validation. Can you check the log of the harvest operation?
SameerBajracharya
hi again!
Hi Wallace,
Thank you so much for your help, I successfully manage to get harvested most of the datasets. But few didn't match validation of geoportal, I will check on those datasets.
best regards,
sameer
AkliluTeklesadik
Dear All,
I have a problem in registering a geonetwork node in geoportal. look at the attachment for the error I am getting
please somebody help me
thanks a lot
Aklilu
[ATTACH=CONFIG]26642[/ATTACH]
MattBertrand
Aklilu,
I am having the same problem, have you found a solution yet?
-Matt
Dear All,
thanks a lot
Aklilu
