Search Not Returning Results
1428
08-17-2011 05:53 AM
KyleChouinard
Hello, I recently setup a geoportal v1.1.1
I was able to add content using the desktop publish client and I can see and search the metadata in the admin tab, I can also use the browse tab to find and display meta data.
The problem is that the search tab doesn't give any results.
KristenWobbe
Occasional Contributor II
One easy thing to check for is whether you have changed the status of the published record on the Administration tab from "posted" to "approved."  The metadata will be discovered in the search results if it has "approved" status.
~k
