This 3-day course teaches how to access the Python environment in ArcGIS Pro, script common data management tasks, and automate geoprocessing workflows. You'll learn techniques to share your scripts so they are easily accessible both inside and outside ArcGIS Pro. These resources are dynamic and will be updated as needed.
Resources
Lesson 1 - Python automation for your organization
- ArcGIS Pro Help
- Dev Summit 2018 Video
Lesson 2 - Using geoprocessing tools in Python
Lesson 3 - Using Describe Objects
Lesson 4 - Automating Python Scripts with Lists
- ArcGIS Pro Help
- Python Help
Lesson 5 - Working with Cursors
A new data access module (arcpy.da) was added in ArcGIS 10.1. The previously existing cursors (that are still listed under arcpy) are still functional and valid; however, the new arcpy.da cursors include significantly faster performance. In most cases, the help will illustrate the use of the arcpy.dacursors. |
Lesson 6 - Working with Geometry objects
Lesson 7 - Using ArcGIS Notebooks
- ArcGIS Blog
- ArcGIS Pro Help
- Web Course
Lesson 8 - Creating a Python Script tool
Lesson 9 - Adding Validation to Script tools
Lesson 10 - Using Python script tools in the platform
- ArcGIS Pro Help
- Esri Youtube Dev Summit Video
Python Related GeoNet Communities
