Yes, Mark, you can use your own point feature class as accuracy assessment points. You will have to manually add the two fields to calculate the confusion matrix, the Classified and the GrndTruth fields. Then use the Update Accuracy assessment points tool twice, once to populate the Classified, then to populate the GrndTruth field. Once both fields have values, you can use Compute Confusion Matrix to generate the confusion matrix.
