Inserted point 0 (x10000): 172.875856, -34.317553 Inserted point 1 (x10000): 173.938053, -34.969507 Inserted point 2 (x10000): 174.927365, -35.880395 Table envelope: xMin=172.000000 yMin=-35.000000 xMax=174.000000 yMax=-34.000000 Calculated envelope: xMin=172.875856 yMin=-35.880395 xMax=174.927365 yMax=-34.317553
This has been entered as NIM077138. We are reviewing this and will post our findings.
I pre-populate the envelopes of GEOGCS ArcSDE layers with {-180,-90,180,90}, just
so I don't have to deal with envelope property updates changing the scale at which
ArcGIS displays.
... the table creation XML includes a data envelope property
(look for "Extent" in the .xsd). You should be able to create featureclasses and featuredatasets
with pre-defined extents.
<Extent xsi:type='esri:EnvelopeN'> <XMin>-180.0</XMin> <YMin>-90.0</YMin> <XMax>180.0</XMax> <YMax>90.0</YMax> </Extent>
