File Geodatabase API 1.3 is now available for download.
9398
15
11-30-2012 06:03 AM
LanceShipman
The File Geodatabase API 1.3 is now available for download from the resource center. (http://www.esri.com/apps/products/download/)
What�??s new at 1.3:
  • Added support for MS Visual Studio 2012.
  • Fix the MutlipatchShapebuffer helper functions and correct multipatch documentation errors in the extended_shape_buffer_format.pdf.(NIM078028)
  • QueryEnvelope does not correctly calculate M and Z extent. (NIM082237)
  • Supported GCS (Geographic Coordinate System) and PCS (Projected Coordinate System) updated to match 10.1 sp1.
Fixed Issues:
NIM078028 Fix the MutlipatchShapebuffer helper functions.
NIM082237 QueryEnvelope does not correctly calculate M and Z extent.
NIM084105 MultiPartShapeBuffer::GetMs return the wrong pointer value
NIM085366 Using only a null or empty geometry results in a invalid extent.
UlrichEgger
Thanks for the reply! We keep one's fingers crossed for this!
AdamDavis
Hi Lance,
Thanks for the update. Would be happy to be a beta tester for this - would hopefully help both Esri and ourselves.
Adam
UlrichEgger
Visual Studio 2015 is released. Have you plan to release File Geodatabase API builds for this version?
LanceShipman
We will not be releasing a VS 2015 build for the 1.4 version of the API. We will include a VS2015 build in the next release. We have several priority issues ahead of this, but I expect we will release before the next Dev Summit. I'll post status when I have it.
Lance
ChristianMaire1
The Dev Summit was over three months ago.  Is there any new status on the VS2015 build / next release?
LanceShipman
We are planning a release in the fall. I'll be posting details next week.
Lance
