File Geodatabase row.SetValue error
3264
04-04-2013 02:22 PM
PrzemyslawTyrtania
I have a Text field with Length of 1073741822 (pretty long) I'm able to set value with no error but getting value throws following error: The value type is incompatible with the field type. Code is simple:
string text = row.GetString("fieldName");
if i query row.FieldInformation i get correct results: Field type is String and Length is 1073741822
We're using v1.2 but i dont see anything in 1.3 that would fix this.
We found a solution to this, and it seems to be a bug in API:
This works:
foreach (Row dRow in RowCollection)
                    dRow.GetString(fieldname);
This doesn???t work:
Row row = null;
                    Row = dRow;
                    break;
row.GetString(fieldname);
This doesn't work
Row row = RowCollection.First();
VinceAngelo
Esri Esteemed Contributor
In the first example, the Row is in scope.  In the second it is not.  The third usage
is rather odd; I'm not suprised it doesn't work -- cursors have a lifetime, after all.
Have you tried extracting the data while the row was in scope?  That is the expected
use pattern.
A gigabyte text field, while legal, isn't likely to be the most efficient way to
manage data.
BTW: At five months since release, you really ought to be using the v1.3 release.
- V
PrzemyslawTyrtania
use pattern.
manage data.
- V
Yea i should have cleaned up that code a bit before posting, it was a copy/paste from email, either way it doesn't work, the idea of code below is to take the first row from collection so that i can return it and other function will modify it later, or maybe i want to modify it in the same method, either way it will error.
Row row = null;
   row = dRow;
   break;
i will update to v1.3 but since this is really a cursor that you're impleneting i will probably get same results, howerver you guys should have really named this a 'cursor' and why include all of these collection methods if they do not work ie .First() since everything must be done in scope none of them will work.
VinceAngelo
You haven't provided enough code to see your Search parameters; if you specified
a true on recycling, then it's not surprising that the Rows in the enumeration are
not durable.
Note: If you use the "Code" block operator ("#" in th editor UI), then the Forums
will preserve your indent scheme.
- V
