So I finally got a chance to get back to this problem.
Code that creates 1 feature with an arc in it. When you look at that feature in ArcMap it doesn't have the correct area or length.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Esri.FileGDB;
using System.IO;
namespace GeoDBTest
class Program
static void Main(string[] args)
CPoint[] arrPoints = {
new CPoint(280216.393,336991.323),
new CPoint(280218.563,336609.378),
new CPoint(280116.567,336609.378),
new CPoint(280116.567,336993.493),
// arc lies between point 1 & 2
CArc arc = new CArc(new CPoint(280116.567, 336993.493), new CPoint(280116.567, 336609.378), new CPoint(279953.806, 336801.436));
Geodatabase geodatabase = null;
string geoPath = "geoTest.gdb";
geodatabase = OpenGeoDB(geoPath);
Table tblTestArea = null;
if(geodatabase != null)
ClearTable(geodatabase);
tblTestArea = OpenGDBTable(geodatabase);
if(tblTestArea != null)
int iMultipart = 1, iPoints = 5, iArcs = 1;
uint iSize = (uint)(4 * sizeof(int) + iMultipart * sizeof(int) + 4 * sizeof(double) + (2 * sizeof(double) * iPoints) + ((sizeof(int) * 3 + sizeof(double) * 2) * iArcs));
int offset = 0;
Byte[] shapeBuffer = new Byte[iSize];
// type
int type = (int)Esri.FileGDB.ShapeType.GeneralPolyline;
type = 536870963; //Byte 29,28 ON and Byte 0 is 51
Buffer.BlockCopy(BitConverter.GetBytes(type), 0, shapeBuffer, offset, sizeof(int));
offset += sizeof(int);
// Extent
// 280116.567 336609.378
// 280220.013 336607.577
// minimum X
Buffer.BlockCopy(BitConverter.GetBytes(arc.pMidPoint.dX), 0, shapeBuffer, offset, sizeof(double));
offset += sizeof(double);
// minimum Y
Buffer.BlockCopy(BitConverter.GetBytes(arrPoints[2].dY), 0, shapeBuffer, offset, sizeof(double));
// 280218.563 336991.323
// 279945.499 336995.913
// maximum X
Buffer.BlockCopy(BitConverter.GetBytes(arrPoints[0].dX), 0, shapeBuffer, offset, sizeof(double));
// maximum Y
Buffer.BlockCopy(BitConverter.GetBytes(arrPoints[0].dY), 0, shapeBuffer, offset, sizeof(double));
// number of parts
Buffer.BlockCopy(BitConverter.GetBytes(iMultipart), 0, shapeBuffer, offset, sizeof(int));
// number of points
Buffer.BlockCopy(BitConverter.GetBytes(iPoints), 0, shapeBuffer, offset, sizeof(int));
// load number of parts
Buffer.BlockCopy(BitConverter.GetBytes(0), 0, shapeBuffer, offset, sizeof(int));
// Load all points
for (int pt = 0; pt < arrPoints.Count(); pt++)
Buffer.BlockCopy(BitConverter.GetBytes(arrPoints[pt].dX), 0, shapeBuffer, offset, sizeof(double));
Buffer.BlockCopy(BitConverter.GetBytes(arrPoints[pt].dY), 0, shapeBuffer, offset, sizeof(double));
// number of Arcs
int numCurves = 1;
Buffer.BlockCopy(BitConverter.GetBytes(numCurves), 0, shapeBuffer, offset, sizeof(int));
// Load ARC
//segment point index - arc is starting from point 2
Buffer.BlockCopy(BitConverter.GetBytes(2), 0, shapeBuffer, offset, sizeof(int));
//segment type 1- circular arc
Buffer.BlockCopy(BitConverter.GetBytes(1), 0, shapeBuffer, offset, sizeof(int));
// ESRI expecting the center point of the 2 cord not the center of the circle (curve)
CPoint arcMidPoint = arc.pMidPoint;
// Center point
Buffer.BlockCopy(BitConverter.GetBytes(arcMidPoint.dX), 0, shapeBuffer, offset, sizeof(double));
Buffer.BlockCopy(BitConverter.GetBytes(arcMidPoint.dY), 0, shapeBuffer, offset, sizeof(double));
// It doesn't matter it calculates the arc based on the mid point
int minor = 16;
int bits = 256 | 128 | 0 | 0 | minor | 0 | 4 | 2 | 0;
// copy bits
Buffer.BlockCopy(BitConverter.GetBytes(bits), 0, shapeBuffer, offset, sizeof(int));
// Loading to the Geo Table
Row polyRow = tblTestArea.CreateRowObject();
ShapeBuffer polylinesGeometry = new ShapeBuffer(iSize);
polylinesGeometry.Allocate(iSize);
polylinesGeometry.shapeBuffer = shapeBuffer;
polylinesGeometry.inUseLength = iSize;
//MultiPartShapeBuffer multiGeometry = polylinesGeometry;
polyRow.SetGeometry(polylinesGeometry);
tblTestArea.Insert(polyRow);
tblTestArea.Close();
tblTestArea.Dispose();
geodatabase.Close();
geodatabase.Dispose();
static Geodatabase OpenGeoDB(string geoDbPath)
Geodatabase geodb = null;
try
try
geodb = Geodatabase.Open(geoDbPath);
catch (Exception ex)
//ignore if file is not present
try
if (geodb == null)
geodb = Geodatabase.Create(geoDbPath);
finally
return geodb;
static Table OpenGDBTable(Geodatabase geodatabase)
Table geodbTbl = null;
string catPath = "";
string tblName = "";
string templatePath = @"PARCELS_TEMPLATE.xml";
try
string featureClassDef = "";
using (StreamReader sr = new StreamReader(templatePath))
while (sr.Peek() >= 0)
featureClassDef += sr.ReadLine() + "\n";
sr.Close();
catPath = @"/FD=CAD2GIS/FC=" + "AreaTest";
tblName = "AreaTest";
featureClassDef = featureClassDef.Replace("_CATLOGPATH_", catPath);
featureClassDef = featureClassDef.Replace("_TABLENAME_", tblName);
geodbTbl = geodatabase.CreateTable(featureClassDef, "");
finally
return geodbTbl;
static Table ClearTable(Geodatabase geodatabase)
Table tblData = null;
try
geodatabase.Delete(tblName, "Table");
finally
return tblData;
} // end class
class CPoint
public double dX;
public double dY;
public CPoint(double x, double y)
dX = x;
dY = y;
class CArc
public CPoint pStartPoint;
public CPoint pEndPoint;
public CPoint pMidPoint;
public CArc(CPoint SPoint, CPoint EPoint, CPoint MPoint)
pStartPoint = new CPoint(SPoint.dX, SPoint.dY);
pEndPoint = new CPoint(EPoint.dX, EPoint.dY);
pMidPoint = new CPoint(MPoint.dX, MPoint.dY);
