Hi, I am doing my thesis work on LiDAR data. I try to clip shape file based on (.adf) file. I could not find the right tool or help for this operation. I tried clip but computer does not understand (.adf) as raster format. I tried to convert it to TIFF ( by export-save as .tif) but it did not solve the problem. It would be good if someone could help me with this issue. Thanks in advance..
clip requires a featureclass to do the clipping. What tool are you trying to use?
Two Clip tools in Arc toolbox:
One for raster as Dan mention --> Arc Toolbox > Data Management Tools > Raster > Raster Processing > Clip
Second for Vector Data --> Arc Toolbox > Analysis > Extract > Clip
I think the OP wants to clip using a raster... both tools noted use vector inputs. The extent of the raster can be used to create a clipping extent.
My pervious comment for clarify .
Dan, the tool always relate to Input that will process on .The first tool for clipping Raster input ( ESRI doesn't put it in Raster toolset for nothing), and the second tool in my post for clipping vector Input.
Ok... I was just clarifying that he wanted to clip a vector using a raster, which no tool does.
It seems ArcGIS does not have straight tool for this operation. Basically I have a .adf file of a forest land (36km2) and a river network of relatively large area; I was trying to clip that river shape file only to that extent. I was thinking if I create a new shape file with same extent as raster and use this as filter to clip the shape file. I will check it when I reach to University ( I don't have ArcGIS at home)
You can take your original raster and then convert it into a raster with only 1's or No data using the raster calculator.
With a function like Con(IsNull(Ras), Ras, 1).
Then convert this to a polygon using
Thanks this works. Thanks you all, this is really a active and useful communityL Another question; why does the .tif file I converted from .adf file is not recognized by ArcGIS as raster. I tried to operate simple (erase, clip..) operation but when I navigate to the file location ArcGIS does not recognize the file .
I think you will have to give us more info to comment.
Sorry, if my previous suggestion worked for you, in what way does Arc not recognise the tif?
