Edit Log Started at: 5/17/2017 1:03:13 PM
Attribute Assistant start editing
Process Count: 0
Unwiring the events
CP_Test_Location - ON_CREATE
Starting AA
############ 5/17/2017 1:03:30 PM ################
Setting sort order: Field - RUNORDER
Querying table for Last Value for layer: CP_Test_Location
Query Used: (TABLENAME = '*' OR TABLENAME = 'CP_Test_Location' OR TABLENAME like 'CP_Test_Location|*' OR TABLENAME like 'CP_Test_Location|%') AND VALUEMETHOD = 'Last_Value'
Number of results: 0
Querying table for rules for layer: CP_Test_Location
Query Used: (TABLENAME = '*' OR TABLENAME = 'CP_Test_Location' OR TABLENAME like 'CP_Test_Location|*' OR TABLENAME like 'CP_Test_Location|%') AND ON_CREATE = 1
Number of results: 2
Looping through the rows
Row Info
Row Number 1
TableName: CP_Test_Location
FieldName: CPCNTRLNUM_A
ValueInfo: Gas_Main_Dec30th_2016|CPCNTRLNUM|F
ValueMethod: INTERSECTING_FEATURE
On Create: 1
On Change: 0
Checking for Subtype Restriction
Field Name: CORCON Control Number A was found at index: 22
Trying: INTERSECTING_FEATURE
Starting to process rule
Value Info is: Gas_Main_Dec30th_2016|CPCNTRLNUM|F
Layer Found: Gas_Main_Dec30th_2016
CPCNTRLNUM: at 68
map tolerance: 1.5625000000058
spatial tolerance: 0.00328083333333333
Using Layer: Gas_Main_Dec30th_2016
Searching on Layer
Selected features count:1
Searching on Selection Set
Cursor created
Starting Loop of found features
Checking Class
Different FCs
Setting Value: 801345456
Value Set
Feature count: 0
Option: First
Finished: INTERSECTING_FEATURE
Row Info
Row Number 2
FieldName:
ValueInfo: Gas_Main_Dec30th_2016|CPSYSTEMSTATUS|UP
ValueMethod: UPDATE_INTERSECTING_FEATURE
On Create: 1
On Change: 1
Field is not specified, empty, or set for all.
Trying: UPDATE_INTERSECTING_FEATURE
Getting Value Info
Checking values
UP at index -1
Value used UP
Finished: UPDATE_INTERSECTING_FEATURE
DONE
Gas_Main_Dec30th_2016 - Created through AA rules - Running ON_CHANGE
Starting AA
Querying table for Last Value for layer: Gas_Main_Dec30th_2016
Query Used: (TABLENAME = '*' OR TABLENAME = 'Gas_Main_Dec30th_2016' OR TABLENAME like 'Gas_Main_Dec30th_2016|*' OR TABLENAME like 'Gas_Main_Dec30th_2016|%') AND VALUEMETHOD = 'Last_Value'
Querying table for rules for layer: Gas_Main_Dec30th_2016
Query Used: (TABLENAME = '*' OR TABLENAME = 'Gas_Main_Dec30th_2016' OR TABLENAME like 'Gas_Main_Dec30th_2016|*' OR TABLENAME like 'Gas_Main_Dec30th_2016|%') AND ON_CHANGE = 1
Number of results: 1
Row Info
Row Number 1
TableName: Gas_Main_Dec30th_2016
FieldName: OPERATINGSTATUS
ValueInfo: RETPL|Retired_Gas_Main
ValueMethod: COPY_FEATURE
On Create: 0
On Change: 1
Field Name: Operating Status was found at index: 65
Trying: COPY_FEATURE
Feature and valueinfo is valid
Splitting up value info: RETPL|Retired_Gas_Main
COPY_FEATURE: Field listed in the Field Name did not change, skipping
Finished: COPY_FEATURE
DONE
Wiring the events
Process Count: 0
Unwiring the events
Starting AA
############ 5/17/2017 1:03:54 PM ################
Row Info
Row Number 1
On Create: 1
On Change: 0
CPCNTRLNUM: at 68
Searching on Layer
No Selected features
No Selected Features
Cursor created
Checking Class
Different FCs
Setting Value:
Value Set
Feature count: 0
Option: First
Row Info
Row Number 2
FieldName:
On Create: 1
On Change: 1
Getting Value Info
Checking values
UP at index -1
Value used UP
DONE
Starting AA
Row Info
Row Number 1
On Create: 0
On Change: 1
DONE
Wiring the events
Process Count: 0
Unwiring the events
Starting AA
############ 5/17/2017 1:04:14 PM ################
Row Info
Row Number 1
On Create: 1
On Change: 0
CPCNTRLNUM: at 68
Searching on Layer
Cursor created
Checking Class
Different FCs
Setting Value:
Value Set
Feature count: 0
Option: First
Row Info
Row Number 2
FieldName:
On Create: 1
On Change: 1
Getting Value Info
Checking values
UP at index -1
Value used UP
DONE
Starting AA
Row Info
Row Number 1
On Create: 0
On Change: 1
DONE
Wiring the events
Process Count: 0
Unwiring the events
Starting AA
############ 5/17/2017 1:04:59 PM ################
Row Info
Row Number 1
On Create: 1
On Change: 0
CPCNTRLNUM: at 68
Searching on Layer
Cursor created
Checking Class
Different FCs
Setting Value:
Value Set
Feature count: 0
Option: First
Row Info
Row Number 2
FieldName:
On Create: 1
On Change: 1
Getting Value Info
Checking values
UP at index -1
Value used UP
DONE
Starting AA
############ 5/17/2017 1:05:00 PM ################
Row Info
Row Number 1
On Create: 0
On Change: 1
DONE
Wiring the events
Attribute Assistant is being suspended
Attribute Assistant is being turn off
Closing Log File 5/17/2017 1:05:11 PM
