Help with IIF statement
1179
02-17-2017 08:31 PM
MikeOnzay
Occasional Contributor III
I'm trying to build a nested IIF statement in a dynamic table that will populate a field I'm using to show an image in my popup window on Portal.
Works:
IIF([MUTCD_ID]="UNK", "no image",IIF([SIGN_CATEGORY]=1,"regulatory","no image"))
Doesn't work:
IIF([MUTCD_ID]="UNK", "no image",IIF([SIGN_CATEGORY]=1,"regulatory/[MUTCD_ID]","no image"))
Row Info
Row Number 2
TableName: Sign
FieldName: EXISTING_IMAGE_LINK
ValueInfo: IIF([MUTCD_ID]="UNK", "no image",IIF([SIGN_CATEGORY]=1,"regulatory/[MUTCD_ID]","no image"))
ValueMethod: EXPRESSION
On Create: 0
On Change: 0
Checking for Subtype Restriction
Field Name: EXISTING_IMAGE_LINK was found at index: 31
Trying: EXPRESSION
replace field: SIGN_CATEGORY with a value
replace field: MUTCD_ID with a value
Checking to verify there is a field to store the expression
Expression to be eval: IIF("R7-1"="UNK", "no image",IIF(1=1,"regulatory/"R7-1"","no image"))
ERROR: evaluating the expression for feature in Sign with OID of 10419
Expected ')'
Finished: EXPRESSION
I don't know why it is expecting a closed parentheses. I've tried various things and it keeps throwing out this same error. The expression that works has the same number of parentheses.
MikeMillerGIS
Esri Frequent Contributor
Change this
Doesn't work:
IIF(="UNK", "no image",IIF(=1,"regulatory/" & ,"no image"))
you need to concatenate the variable and the string, might be a + instead of &, I am rusty on VB
Sent from my Verizon Wireless 4G LTE DROID
JoeBorgione
Have you looked at the offending feature with OID 10419?  Purely a WAG (wild a$$ guess).  Is there a <null> value where there shouldn't be?
That should just about do it....
MikeMillerGIS
Change this
Doesn't work:
MikeOnzay
In response to the first reply I recreated the scenario in a file GDB with 3 columns to eliminate any other possibilities. The image below is showing the field alias and I still received the same error.
In response to your suggestion of concatenating the string and variable I get the same error.
ValueInfo: IIF([MUTCD_ID]="UNK", "no image",IIF([SIGN_CATEGORY]=1,"regulatory/"&[MUTCD_ID],"no image")
Expression to be eval: IIF("R7-1"="UNK", "no image",IIF(1=1,"regulatory/"&"R7-1","no image")
ERROR: evaluating the expression for feature in sign with OID of 1
Expected ')'
It turns out that using + as a concatenation operator is valid in VBA for numbers AND strings. It worked.
ValueInfo: IIF([MUTCD_ID]="UNK", "no image",IIF([SIGN_CATEGORY]=1, "regulatory/"+[MUTCD_ID],"no image"))
What really started me down this path was wanting to force the value to lowercase. It works now.
IIF([MUTCD_ID]="UNK", "no image",IIF([SIGN_CATEGORY]=1, "regulatory/"+LCase([MUTCD_ID]),"no image"))
Setting Value to: regulatory/r7-1
Thanks!
