When using Intersecting_Edge, you only need to specify the field, not Layer|Field in the value info as it detects the edge from the geometric network----We don’t have geometric network built in so I am not sure whether method works for us.
For intersecting feature with lots of features, what scale are you editing at? It depends on Technician; we don’t have standard scale value.
The current code evaluates the map tolerance as well as the xy resolution to ensure the point finds the line. The problem with the map tolerance is as you zoom out, the search area widens, I think I revert this and only use data tolerance —I noticed that too , now adding feature is not taking too long.
Your map, you do not happen to be in Decimal Degrees, are you?----No we don’t.
Also expose a new option in the aa.config to clear the last value on stop editing like you requested.--- It works now, whenever I stop the edits it erases my values. This is what we are looking for.
Mike ,thanks for your help.Awesome work!
