I've run into a problem with an Oracle View that produces duplicates of column OBJECTID.
The underlying geo-table has of course unique objectid:s but in the view, every geometry can occur severeal times. This violates functionality that requires that the ObjectID be unique. https://desktop.arcgis.com/en/arcmap/latest/manage-data/using-sql-with-gdbs/object-id.htm
The view is a registred view in ArcGIS.
In my case I have a ArcMap service that consumes the view and when duplicate objectids are spotted it aggregates all rows with the same objectid. Maybe thats fine with the geometrys, as many lines can exist in a poly line field. The problem is the attributes where only one of aggregated rows will represent the geometry/row when consumed in the map service. Maybe it's the first row of the aggregated records that will display in the map or one of the others, it's hard to tell. It feels random.
Is there a best practise to solve this kind of issue?
I have tried to make the view generate it's own unique value in the OBJECTID column instead reading that's written in the underlying table but when I do this it's not possible to register the view in ArcGIS.
