If those suggestions don't get what you are aiming to get, another option is my Python addin for data inventory and “broken-link” repair. ....the second button will inventory everything, and output a .txt, .csv, and .xls with a date/time stamp in the file names, so you can run and compare. I don't have a record count, but may be something I will add. I'm actually trying to get an addin for inventorying items in a number of ways, including what's within mxd's (in a goal to know what services I need to shutdown to update a fgdb).
Anyway, the .xls output for the inventory button looks like
purposely left simple.
I think I've made a few changes since I posted the addin, so he is some code that should be able to run as a standalone....just need to change the workspace you want to inventory (need write access to same folder for the output) (I can upload the .py if this doesn't work) Even this was last worked on a while ago, so could be cleaned up a bit.
Tool: FCInventoryReport
Toolbox: CheckAndFixLinks.tbx
Script: 2_InventoryFCs.py
Purpose:
This script will walk thru all the feature classes within a folder
and create a text report, comma-delimted and an Excel .xls file.
Include shapes, coverages, rasters, tables, connections, and FGDB
Column names: FType FCname FullPath
Author: Rebecca Strauch - ADFG-DWC-GIS
Created on: 4/10/2013
last modification: August 10, 2015
Description: To create list of the features classes within a folder, including
coverages (pts, poly, arc, anno), shapes, grids and FGDB data. Outputs list
to a text report file (not much formatting) in the folder being scanned named
FCInventoryYYYYMMDD_HHMM.txt
with the date and time as part of the name. This should always create
a new file, unless you run it twice within same minute.
Must have write permissions on the output folder in question.
Known issue (with built-in workaround): for some reason some, but not
all (ArcInfo) grids want to duplicate the folder name before the
describe. I'm now checking to make sure it exists, if not, I am removing
the duplicate portion, and letting it run. Seems to work.
Arguments:
[0] theWorkspace: Folder/directory to search (walk thru, includes subfolders)
[1] outFile: output base filename, default GDBList, script appends YYYYMMDD_HHMM
Updates:
# Import modules
import arcpy
import os
from _miscUtils import *
from _gpdecorators import *
def myMsgs(message):
arcpy.AddMessage(message)
print(message)
# catch_errors decorator must preceed a function using the @ notation.
@catch_errors
def main():
Main function to create text file report of all Feature Classes in folder
#setup environment
# Script arguments...
""" If running as standalone, hardcode theWorkspace and outFile """
theWorkspace = arcpy.GetParameterAsText(0)
if not theWorkspace:
theWorkspace = r"C:\__temp" # r"D:\_dataTest"
outFile = arcpy.GetParameterAsText(1)
if not outFile:
outFile = "FCInventory"
# Create new output name name tagged with YYYYMMDD_HHMM
fileDateTime = curFileDateTime()
currentDate = curDate()
# Create new output name tagged with YYYYMMDD_HHMM
outfileTXT = os.path.join(theWorkspace, outFile) + fileDateTime + ".txt" #theWorkspace + "\FCInventory" + fileDateTime + ".txt"
outFileCSV = os.path.join(theWorkspace, outFile) + fileDateTime + ".csv" #theWorkspace + "\FCInventory" + fileDateTime + ".csv"
outFileXLS = os.path.join(theWorkspace, outFile) + fileDateTime + ".xls"
arcpy.AddMessage(theWorkspace + ", " + outfileTXT)
reportFile = open(outfileTXT, 'w')
csvFile = open(outFileCSV, 'w')
arcpy.AddMessage( "File {0} is open? {1}".format(outfileTXT, str(not reportFile.closed)))
arcpy.AddMessage( "File {0} is open? {1}".format(str(outFileCSV), str(not csvFile.closed)))
#arcpy.AddMessage( "File " + str(csvFile) + " is closed? " + str(csvFile.closed))
arcpy.AddMessage("Writing the report to: " + outfileTXT + " and " + outFileCSV)
outText = "List of all GIS data in " + theWorkspace + " on " + currentDate + '\n'
outText += " Includes coverages (pts, poly, arc, anno), shapes, and FGDB data." + '\n'
outText += "-----------------------------------------------------" + '\n'
reportFile.write(outText)
csvFile.write("FType, FCname, FullPath\n")
def inventory_data(workspace, datatypes):
for path, path_names, data_names in arcpy.da.Walk(
workspace, datatype=datatypes):
if "tic" in data_names:
data_names.remove('tic')
for data_name in data_names:
fcName = os.path.join(path, data_name)
#arcpy.AddMessage("Show for debug: " + fcName)
if not arcpy.Exists(fcName):
# workaround for raster folder name duplicating
fcName = os.path.dirname(fcName)
desc = arcpy.Describe(fcName)
#arcpy.AddMessage("debug, desc it to me: " + desc.dataType)
yield [path, data_name, desc.dataType] #, desc]
i = 0
for feature_class in inventory_data(theWorkspace, "FeatureClass"):
""" last modified data not working for gdb or FC in fgdb ..."""
#lastMod = time.strftime('%m/%d/%Y %H:%M', time.localtime(os.path.getmtime(feature_class[0])))
if i == 0:
#arcpy.AddMessage("{0} modified: {1}".format(feature_class[0], lastMod))
arcpy.AddMessage("{0}".format(feature_class[0]))
outText = ' ' + feature_class[0] + '\n'
path0 = feature_class[0]
i =+ 1
elif not path0 == feature_class[0]:
i = 0
if feature_class[2] == "ShapeFile":
shpfile = arcpy.os.path.join(feature_class[0], feature_class[1])
lastMod = time.strftime('%m/%d/%Y %H:%M', time.localtime(os.path.getmtime(shpfile)))
arcpy.AddMessage(" {0}: {1} modified: {2}".format(feature_class[2], feature_class[1], lastMod))
outText = (" {0}: {1} modified: {2}\n".format(feature_class[2], feature_class[1], lastMod))
else:
arcpy.AddMessage(" {0}: {1}".format(feature_class[2], feature_class[1]))
outText = (" {0}: {1}\n".format(feature_class[2], feature_class[1]))
csvFile.write("{},{}, {}\n".format(feature_class[2], feature_class[1], feature_class[0]))
reportFile.close()
csvFile.close()
arcpy.AddMessage( "File {0} is closed? {1}".format(outfileTXT, str(reportFile.closed)))
arcpy.AddMessage( "File {0} is closed? {1}".format(outFileCSV, str(csvFile.closed)))
# Creates Excel .xls file from the .csv ....easier to edit (ver 1)
arcpy.TableToExcel_conversion(outFileCSV, outFileXLS)
arcpy.AddMessage('!!! Success !!! ')
# End main function
if __name__ == '__main__':
main()
EDIT: uploaded my _miscUtils and _gpdecorators in case that throws people off. The code above can be modified to not use them...but I use them for convenience, and often forget to remove before posting other code. Just drop the two .py in the same folder as the script above.
