I've encountered an issue with registering tables now that the new "high precision" datetime field is available in 3.2/11.2, where when testing an identical, empty table and field, occasionally ArcGIS Pro registers it as a regular "low precision" datetime field, and the rest of the time Pro considers it a "high precision" datetime field. This is using MS SQL Server (DATETIME type, not DATETIME2(7)). We do not currently wish to employ the "high precision" datetime type.
When creating a table within ArcGIS Pro 3.2, we can create a datetime field and then migrate that field to high precision using the Esri tool afterwards. That's not an issue.
However, when we register pre-existing tables created through SSMS using the Register with Geodatabase tool, we encounter some weird behavior. We have done several tests with multiple databases and tables, and sometimes Pro registers the table as a regular datetime field, and sometimes it registers it was a "high precision" datetime field.
We performed these tests on the exact same tables in multiple databases, and it is using the regular datetime field type in SQL Server. And sometimes Pro registers it as "high precision", and other times it does not.
This is very problematic for us because there is no way (to my knowledge) to "downgrade" to a non-precision datetime field in Esri, and it is only compatible with ArcGIS Enterprise 11.2, meaning we can't publish feature services containing "high precision" datetime fields to lower Enterprise versions.
Is there anyway we can "force" ArcGIS Pro to recognize a field as non-high precision when registering a table with the geodatabase? Or is this a bug or something, because we need Pro to be consistent when registering tables with the geodatabase and not just randomly picking and choosing to use "high precision" or not.
