Is anyone experiencing the behavior below? ArcCatalog performs the following task just fine.
Scenario: In ArcGIS Pro (currently 2.9.1), I right-click a feature class in an enterprise geodatabase (logged in as the class' owner and dbo), and select Locks from the context menu. I right-click a lock in the list and select View User.
Expected behavior: I should be taken to the Connections tab and the User row in question should be highlighted.
Actual behavior: I am taken to the Connections tab and no rows are highlighted.
I suppose I can script this, but the UI should be sufficient for us.
