Add a features file name to its attribute table?
578
08-14-2012 10:24 AM
DavidMedeiros
I'm wondering if there is a way to populate an attribute field for a feature with that features name?
I have a series of about a thousand polygons as shape-files. The attributes for each are identical, ID 0. But the names are unique, in fact each name encodes 3 attribute values for each feature. I need to merge all of these features into a single feature class but maintain the unique name for each in the new attribute table (to later be parsed into separate fields). Is there a tool or script for adding the name of a feature to its table?
SolomonPulapkura
You'd have to do something like
# get the shapefile name
n = arcpy.Describe(shp).name
# open an update cursor
ucur = arcpy.UpdateCursor(shp)
for urow in ucur:
    urow.FCNAME = n # assuming a field called FCNAME exists
    ucur.updateRow(urow)
