Arcgis very slow
5878
22
05-20-2015 08:20 PM
joycemaia
New Contributor III
Hello!
Does anyone know how I can speed up the process Join Space ?. On my machine it has taken too long.
This is my setup
i5 3.0 GHz
8GB RAM
thanks
Tags (1)
DanPatterson_Retired
We need details.  Featureclasses? shapefiles? files on local disk? on network? are the files indexed? size?
or use small, indexed featureclasses stored on a local disk
joycemaia
New Contributor III
The files are quite large, but I have done it before and had not taken so long.
I formatted the computer and now I'm with Win8
All files are on the PC, look at the printscreen of an example of all my files.
The idea is to cross points to polygons
Another issue is very different save files in a specific folder to save the directory: C: \ Users \ Joyce \ Documents \ ArcGIS \ Default1.gdb
Captura de tela 2015-05-21 00.44.18.pngCaptura de tela 2015-05-21 00.42.56.png
See Curtis's comments in this thread regarding *.mxd's
Performance problems in desktop 10.3.1?
​So 2 things.  First, save to a simpler drive path...you should only use that c:\user\thingy folder for photos and junk
  • Create/use a simpler folder ie c:\gis\file
  • copy both files there
  • start a new project and add both files either as shapefiles or send them to a new geodatabase
  • make sure that they are in the SAME coordinate system...looking like they are isn't good enough...Use the Project tool to get them into the same projected coordinate system
  • index the Shape field for both files
  • try again
good luck
joycemaia
New Contributor III
Thanks for the tips, will launch a new project this way to see if it helps.
joycemaia
New Contributor III
Do you think that kind of projection could influence this type of analysis (join space)?
joycemaia
New Contributor III
The shapes of the polygons were reprojected to Albers. The shape with the points I make from my data, first I do it in WGS after reprojected to Albers
These are the files of properties
The Datum makes sense with the projection?
Data Type:Shapefile Feature Class
Shapefile:C:\a\south0.shp
Geometry Type:Polygon
Coordinates have Z values:No
Coordinates have measures:No
Projected Coordinate System:South_America_Albers_Equal_Area_Conic
Projection:Albers
False_Easting:0,00000000
False_Northing:0,00000000
Central_Meridian:-60,00000000
Standard_Parallel_1:-5,00000000
Standard_Parallel_2:-42,00000000
Latitude_Of_Origin:-32,00000000
Linear Unit:Meter
Geographic Coordinate System:GCS_South_American_1969
Datum:D_South_American_1969
Prime Meridian:Greenwich
Angular Unit:Degree
curtvprice
MVP Esteemed Contributor
You have a shapefile there that has a dbf approaching the 2GB limit. This is an operating system limit!
You may want to consider putting these feature classes in a file geodatabase. They are pretty big but at least your processing is more likely work at all.
joycemaia
New Contributor III
The file is too large. I have over 4 million points to join with many polygons.
SepheFox
Are you talking about a Spatial Join, Joyce? The projection you use shouldn't slow things down, but as Dan says you do want everything in the same projection. Can you make a file geodatabase in ArcCatalog (right click in your folder, select new-->file geodatabase), then export all your shapefiles into the geodatabase (In ArcCatalog right click one of them, select export-->to geodatabase (multiple), and then add all your shapefiles into the dialog).
