Arcgis very slow
5835
22
05-20-2015 08:20 PM
joycemaia
Hello!
Does anyone know how I can speed up the process Join Space ?. On my machine it has taken too long.
This is my setup
i5 3.0 GHz
8GB RAM
thanks
DanPatterson_Retired
The trouble is that some of the spatial locations are in the water and not on land...nothing is going to fix that except to use a different partitioning space, then associate proximity to country after that
JayantaPoddar
Also turn off background processing.
Think Location
joycemaia
The open when Arcgis uses only 30% of the processor, I changed the process for priority in real time. This did not show much difference.
As for RAM, ArcGIS uses very little. Google Chrome uses a lot more.
Do you think it would be very bad open the ArcGIS three times to run different tasks? So I speed work.
thank you!
