ARCSDESQLEXECUTE and ORACLE stored procedures
3080
04-15-2010 02:21 PM
RyanLuedey
I can't seem to get this combination to work.  According to this thread:
http://forums.esri.com/Thread.asp?c=93&f=1729&t=275646
it should be possible.  Every time I try it I get an "ORA-00900: invalid SQL statement" error.  My SQL statement works fine from TOAD.
Is there a secret to making this work, or does it not work at all?  Any ideas?
Cheers.
DallasShearer
I had the same problem when using sql = execute mystoredproc()
instead use sql = call maystoredproc() to run successful.
DallasShearer
AndresCastillo
MVP Regular Contributor
Marked @DallasShearer  response as correct due to the verification given in this Stack Overflow (SO) thread:
https://gis.stackexchange.com/questions/307592/execute-oracle-stored-procedure-from-arcsdesqlexecute
