Hi Xander,
Thanks for your response.
The code that I am using is as follow:
>>> def main():
... import arcpy
... import os
... fc_in = r"F:\Code.gdb\Data2" # this one exists
... fld_count = "No_Adress"
... fc_out = r"F:\Code.gdb\Points_out" # this one will be created
... sr = arcpy.Describe(fc_in).spatialReference
... # create the empty output featureclass
... path, name = os.path.split(fc_out)
... arcpy.CreateFeatureclass_management(path, name, "POINT", fc_in, "SAME_AS_TEMPLATE", "SAME_AS_TEMPLATE", sr)
... # insert the features into the output fc
... with arcpy.da.SearchCursor(fc_in, '*') as curs_in:
... flds_in = curs_in.fields
... idx_cnt = flds_in.index(fld_count)
... with arcpy.da.InsertCursor(fc_out, '*') as curs_out:
... for row in curs_in:
... cnt = row[idx_cnt]
... for i in range(0, cnt):
... curs_out.insertRow(row)
... if __name__ == '__main__':
... main()
Runtime error
File "
