Was not getting convincing and consisten results, so I tried tests in code block. I think that the "crosses" and "touches" are either wrong or the definitions in the documentation are inconsistent. What do you think?
# test of the various geometry or poly interaction methods
import arcpy
import sys
# define coordinate lists
clist1 = [[0,0], [0,10],[10,10],[10,0],[0,0]]
clist2 = [[10,0],[10,10],[20,10],[20,0],[10,0]]
# define geometry objects
# (0, 10) -------(10, 10)---------(20, 10)
# | P1 | | P2 |
# (0, 0) -------(10, 0)---------(20, 0)
# Intersection along the line (10,0) to (10,10)
aPt = arcpy.Point()
anArray = arcpy.Array()
# Make first polygon
for coordpair in clist1:
aPt.X, aPt.Y = coordpair[0], coordpair[1]
anArray.add(aPt)
polygon1 = arcpy.Polygon(anArray)
# Clear array and push in second coordinate list
anArray.removeAll()
# Make second polygon
for coordpair in clist2:
anArray.add(aPt)
polygon2 = arcpy.Polygon(anArray)
# Method Explanation
# contains (second_geometry) Indicates if this geometry contains the other geometry.
# crosses (second_geometry) Indicates if the two geometries intersect in a geometry of lesser dimension.
# disjoint (second_geometry) Indicates if the two geometries share no points in common.
# equals (second_geometry) Indicates if the two geometries are of the same type and define the same set of points in the plane.
# overlaps (second_geometry) Indicates if the intersection of the two geometries has the same dimension as one of the input geometries.
# touches (second_geometry) Indicates if the boundaries of the geometries intersect.
# within (second_geometry) Indicates if this geometry is contained within another geometry.
# Based on coordinate lists and definitions
# Polygon1 contains Polygon2 = False
# Polygon1 crosses Polygon2 = True Two two-dimensional polygons share a one-dimensional boundary, the line from (10,0) to (10,10)
# Polygon1 disjoint Polygon2 = False
# Polygon1 equals Polygon2 = False
# Polygon1 overlaps Polygon2 = False (Intersection is one-dimensional line (10,0) to (10,10)
# Polygon1 touches Polygon2 = True (Intersect along line (10,0) to (10,10)
# Polygon1 within Polygon2 = False
# Evaluate various polygon methods
test1 = polygon1.contains(polygon2)
test2 = polygon1.crosses(polygon2)
test3 = polygon1.disjoint(polygon2)
test4 = polygon1.equals(polygon2)
test5 = polygon1.overlaps(polygon2)
test6 = polygon1.touches(polygon2)
test7 = polygon1.within(polygon2)
# Evaluate obverse
test8 = polygon2.contains(polygon1)
test9 = polygon2.crosses(polygon1)
test10 = polygon2.disjoint(polygon1)
test11 = polygon2.equals(polygon1)
test12 = polygon2.overlaps(polygon1)
test13 = polygon2.touches(polygon1)
test14 = polygon2.within(polygon1)
print 'Test1 = ', test1
print 'Test2 = ', test2
print 'Test3 = ', test3
print 'Test4 = ', test4
print 'Test5 = ', test5
print 'Test6 = ', test6
print 'Test7 = ', test7
print ' '
print 'Test8 = ', test8
print 'Test9 = ', test9
print 'Test10 = ', test10
print 'Test11 = ', test11
print 'Test12 = ', test12
print 'Test13 = ', test12
print 'Test14 = ', test12
print ' '
