Hi there,
I've been working on some polygons lately and scripting with arcpy in ArcGIS Pro (version 2.8.1).
The main task that I need to do is to generate near tables of AOI shapefiles of every state of the U.S., and each shapefile contains 1,000 to 2,000 small polygons. The search radius we are setting is about 300km, and we are calculating geodesic distances. The projection we're using is azimuthal equidistant.
I created a loop to go through the generating near table process for every state, but no matter if I run it with jupyter notebook within arcpro or as a standalone python script in the command line, it stopped running after the first state. In the arcpro environment, the software just crashed and closed itself. In command line, it also looks like it crashed because no following messages were printed.
I am wondering if there is any particular reason for this to happen and if there is any possible workaround to it.
Really appreciate your time and help! (please help me)
Thanks.
