If you don't have a road network built and just have the bus route layer, a quick partial solution to produce just the overlapping segments that overlap would be this:
1. If your bus routes are in separate feature classes, Merge them into one feature class. Be sure the output has a unique identifier field for each bus route so they can be differentiated.
Merge—Help | ArcGIS for Desktop
2. Run an Intersect on just the combined bus route feature class (i.e. there is only one input - the combined bus route feature class). The resulting feature class will just be the segments that have an overlap. All the segments that were "dropped out" do not overlap (and therefore only have one bus route on them). Of the segments that did show up in the result, if there are only a few, one could individually select each on the map and then check the attribute table to count how many route records are selected in the attribute table.
Intersect - ArcGIS Help (10.2, 10.2.1, and 10.2.2) License note: With ArcGIS for Desktop Basic and Standard licenses, the number of input feature classes or layers is limited to two. So one may have to do several Intersects if one does not have an Advanced license.
Caveat - this assumes the bus route linework is coincident where it overlaps. This is crucial. If the linework is offset by even a small amount in overlap areas, this process will not work correctly. One potential solution if this is an issue is to run the Integrate tool. However, before you do this be sure to back up your data first, as the Integrate tool will alter your source data (it does not create a new output dataset like many other tools do).
Integrate—Help | ArcGIS for Desktop
Chris Donohue, GISP
