I am trying to create 10x10 grids inside of a pre-existing rectangular grid . The starting grid is regularly used by the police, so I can not just create a new grid of the extent from scratch to start from. Unfortunately the rectangle dimensions of the starting grid vary very slightly.
I have tried matching up with the "grid index features" tool, I have also tried using the data reviewer- "create polygon grid wizard". The data reviewer kind of worked but left a ton of overlap everywhere. I have thought about putting the layer into a parcel fabric, but the split polygon tool looks like it only works on one polygon at a time.
I am totally open to thoughts. Maybe there is a good script out there or a tool that I am just missing. I have read through several Geonet posts and not found a good solution. Any comments are welcome!
-Keith
