I'm currently working with a city_streets network shapefile, however I've found that almost all of the streets have been broken up into separate polylines (e.g. 3 separate polylines are all named Main St). Is there a way to merge multiple polylines, with the same attribute (i.e. the street name), together without having to manually do one at a time?
I'm hoping that by doing so, when I click the street segment with the identify tool, it'll just show the whole length of the street segment as Main st. instead of 3 separate ones that are lined up, all called Main St.
Thank you
