Merging not working
3810
07-16-2014 12:05 AM
SoumilGore
New Contributor II
I am facing some issues with ArcGIS 10. When I merge to polygons either of the one or both the polygons gets deleted. I tried this on multiple shapefiles and also on geodatabase, but still getting the same result. this polygons were created as kml on Google Earth and the converted from kml to layer in ArcMap. Projection of both are same. Below are the screenshots of the merging process for reference.
1. Selected one polygon:
Inline image 1
2. Selected another polygon:
Inline image 2
3.Selected merge tool from Editor:
Inline image 3
Inline image 4
4. Result of the merge: Both features got deleted but on of the attribute which was selected at the time of merge is preserved.
Inline image 5
Please look into it and let me know if you need any other detail regarding the same
Thank you,
DanPatterson_Retired
Your images didn't come through...could be a browser issue
In any event, if they are in shapefile format in a folder, run the Check Geometry or Repair Geometry tool to ensure that the translation from KML went smoothly
SoumilGore
New Contributor II
Thank you Dan. It is working now.
SoumilGore
New Contributor II
Hello Dan,
The warning that repair geometry is throwing as incorrect ring ordering. Can you please explain what does it mean, if you know it?
thank you,
Soumil
Exterior rings are supposed to run clockwise and interior rings (ie donut holes) are supposed to run counterclockwise.  Perhaps the software that you used doesn't conform to that standard or it was just corrupt.  I tend to use the free  DNRGps to do my translations since I use GPS frequently and I have had no issues converting between KML and shapefiles
DNR Garmin Application: Minnesota DNR
