I would like to multiple values from one column to another and divide by 100 using calculate value (Model Builder), how do I go about that? Say one column in a shapefile has Area and another one Rating and empty field column for the results. How can I do that
Hi. This is the model I have been doing. It is basically a wetland based model to generate condition of a wetland based on the landcover extent. I basically want to make use of calculator to multiply the field values (say frequency and landcover extent) and be able to divide them by 100 so I can get the results in an unfilled field. Having a challenge making use of calculate value tool from Model builder. Any help will be appreciated and further advice in taking this forward
