I'm moving a python script running in ArcGIS 10.0 to ArcGIS 10.3.1 environment. In that script we are converting a file geodatabase table to an INFO table. This no longer works the same in 10.3.1 as it produces a DBF table rather than an INFO table even though the output table name "taxmaster" does not have the .dbf extension.
arcpy.TableToTable_conversion("C:/Test//TaxMaster2.gdb/taxInfoSort", "//stgisgdb1/testdata//taxmastr", "taxmaster", ...)
Apparently output to INFO table is no longer supported in TableToTable_conversion 10.3.1.
Is this the case and , if so, is there any way to convert from table to INFO table?
