Uploading and using data to a geoprocessing service
15652
28
12-19-2012 07:32 PM
TomSchuller
Hy,
I'm trying to build a simple geoprocessing service which should buffer an uploaded shapefile.
This is the scenario:
  1) uploading shapefile to geoprocessing service
  2) buffering the shapefile with a given parameter
  3) returning the buffered shapefile
The buffering is not the problem, but the handling of the upload and reusing it in the model or python part.
As far as I read, I should have to use a Datafile parameter for upload, but I'm always getting this error while running it:
ExecuteError: Failed to execute. Parameters are not valid. ERROR 000735: input: Value is required Failed to execute
Can anybody help me to use uploads on geoprocessing services?
Tom
KevinHibma
Upload to a GP Service is sort of a multistep process.
You're correct, you do want to use a "file" (GPDataFile) as the input parameter.
If you're using Destkop to consume the service, desktop will send the file to the server.
If you're using a webapp, you're responsible for getting the file to the server. (Server at 10.1 has some upload capabilities in REST you can leverage. If using 10.0 or prior you'll need to devise a way to get the file to the server your self)
Once the file has been upload, because you're talking shape file, you'll have to unzip it. (shapefile being multiple files to make up a single one).
With it unzipped, you can then pass the file to your service.
Based on your error - your file didnt upload, or you never sent it. Whats the client to consume the GP Service - a web app?
TomSchuller
thanks for the quick answer.
Yes, I know it's a multistep process.
I have the problem that I don't see howto handle an uploaded file over gpservice in a model or python script.
Did you have an example of your "unzipModel" scenario, like:
user is uploading data to gpservice (10.1 upload capabilities in rest)
user is calling the unzipModel with the upload-id as parameter (over rest url)
    the model is unzipping the zip file into some directory
I just need to see how I can use the uploaded file in a python script or model directly.
Tom
TomSchuller
I just need to see how I can reuse the uploaded file in a python script or model directly.
Tom
LaurynasGedminas
Having the similar issue here, I created python script to upload text files to SDE,
published the script as GP service and it works in ArcMap and ArcGISExplorer.
In Flexviewer added this GP service with input parameter as "datafile" and i cant upload the files
Laurynas
TomSchuller
Hy,
I didn't yet used it in the FlexViewer but only manually over rest.
But it should point you to the right direction:
  enable "upload" on your geoprocessing service
  upload your file to the gp-service and remember the upload-id
  call your gp-service with the datafile paramater as the text below:
For GPDatafile parameter, you have to indicate this full json representation of the upload item:
parameter = {"itemID":"i80dfa12f-52ed-4841-94ff-37f9c3f5dd6f"}
Tom
AlexandreMatveev
Hello, how can I access to this file in Geoprocessing script? I uploaded the .zip file and passed this object like parameter and I want to unzip it in, but what is the step between pass the parameter and unzip? how do we get access to .zip file? thank you
LaurynasGedminas
Thanks Tom,
I guess I was not clear about my problem
i dont know why flexviewer doesnt display "upload" button on its widget when input data type is set to "datafile"
Laurynas
BjornSvensson
If ESRI will update the geoprocessing widget so it will take a local file,  I, and many other users will be very happy!
Thanks for the suggestion to support local file uploads in the Geoprocessor widget.  We will take a look at this for version 3.2 of the Flex Viewer.  It would most likely just follow the steps outlined by Dasa in the thread you listed: http://forums.arcgis.com/threads/64114-Uploads-capability-on-Geoprocessor.
As for the ArcGIS API for Flex - since the Flash API already supports file upload, I don't think this is something we would add to the ArcGIS API for Flex.
meriyalootka
Hy
I have a model for uploading datafile, every thing is ok and user's zip file extract correctly. But I can not use extracted shapefile. Is there any py code for using feature class in a scratchfolder? Can I have this part of your model?
Hy,
Tom
