@esri_certified_individuals
@esri_technical_support
@tim_witt
i have found few of them why it fails what are the reason.. Can u suggest me with something else more..
MSXML 4.0 SP2 hotfixes and intsalled MSXML 4.0 Service Pack 3
.NET framework 4.5 and tried to install Microsoft .NET Framework 3.5 Service Pack 1
Microsoft .NET Framework 3.5 Service Pack 1 again. FYI - Microsoft .NET Framework 3.5 Service Pack 1
is a requirement for using ArcGIS Desktop 10.1
profile specific
Checked the RAM and memory
Any software updates made to the machine
automatic Microsoft updates, anti-virus updates, etc.
(avast antivirus has a effect on backgroun gp)
64bit background geoprocessing application that was causing the issues
mismatch in the installation of the 64-bit python tools and dlls with other 32-bit parts of the product
One option to try is to just reinstall the 64-bit background gp module and see if the problem returns.
If that happens, the fastest resolution is probably to uninstall all of ArcGIS Desktop, make sure any
relevant registry and disk entries are removed, then reinstall.
The following data types are unsupported in 64-bit processing:
Personal geodatabase (.mdb)
Excel tables (.xls, .xlsx)
OLEDB connections
remaning few of the folders may solve,
C:\Users\\AppData\Roaming\ESRI
Roaming folder above, rename the Esri folder to something else, such as Esri_old.
Go to the Start menu, run Regedit, expand HKEY_CURRENT_USER > Software, and rename the Esri subfolder
