Thanks for your answer! I tried the following call in the Python window of ArcMap and I got an error 440:
arcpy.MakeImageServerLayer_management("https://sentinel.arcgis.com/arcgis/services/Sentinel2/ImageServer", "test", mosaic_method = "BY_ATTRIBUTE", order_field = "AcquisitionDate", order_base_value = "2018/06/22")
Then I remove the last part of the URL and no error was raise but nothing was added to the TOC. I also tried so assign the call to a variable and called arcpy.Describe() on a runtime error was returned. Do you not what's wrong? My ArcMap version is 10.4.1.5696.
arcpy.MakeImageServerLayer_management("https://sentinel.arcgis.com/arcgis/services", "test", mosaic_method = "BY_ATTRIBUTE", order_field = "AcquisitionDate", order_base_value = "2018/06/22")
I was looking a the sort field values available and was wondering what SyncDateTime and DateUpdated meant? Could I use one of these in order to always have the most recent image in my map document? Do you know where I can find the documentation on all those values?
Thanks a lot !
