Anyone no how i can convert to a .jim or .zim file from .tif files?
2331
01-26-2016 12:51 PM
GregSnelling
New Contributor III
I'm trying to import into a legacy application to support some legacy users, but my imagery is .tif, or Mrsid format.
DanPatterson_Retired
I can find zim ... but jim? to what application are your data going? and I don't suppose you have FME available?
GregSnelling
New Contributor III
Thanks Dan-
It's an old application called Photomapper that is no longer supported.  Good idea with FME etl tools.  Maybe I can get a trial version.  Where you able to convert from .tif to .zim using FME?  What about .map?
-Greg
PROBERT68
Who provide these files to you ?
Don't even know...but if FME can't do it directly, then it can't be done.  I would assume that there is some common format spanning the two  Perhaps the legacy users might consider alternates...we had to when card reader access became impossible
PROBERT68
