Thanks Darren,
Actually there is no way around to fix the problem. Even though I tried to delete the Overview folder and still not work...so what I did, yeah, had to re-do all over and got it fixed...
First thing I had to delete the corrupt one..
Create a new dataset
Add rasters with update overview only do not build boundary or footprints
Once you get all the raster done
start building footprints
then build seamlines
check for any overlaps issue
if there is one white anywhere, open up footprint and set up which one you want to set to 1 or 2 in the Z order
build overviews..
All worked out well..
The white hole you see here is a military area where they do not want to be display....in the 2009, there is a full of naip all over the state....
