Build footprints failed
4315
03-12-2015 11:13 AM
PROBERT68
Ugh ! I spent all day trying to figure it out what this means...tried everything to get my raster to re-display again.... feelling frustrated !!!
DarrenWiens2
MVP Honored Contributor
This thread has some ideas, but no definitive answers. Obviously, it looks like there is a problem with two of your rasters. Try creating the mosaic without them and add them in later.
PROBERT68
Thanks Darren,
Actually there is no way around to fix the problem. Even though I tried to delete the Overview folder and still not work...so what I did, yeah, had to re-do all over and got it fixed...
First thing I had to delete the corrupt one..
Create a new dataset
Add rasters with update overview only   do not build boundary or footprints
Once you get all the raster done
start building footprints
then build seamlines
check for any overlaps issue
if there is one white anywhere, open up footprint and set up which one you want to set to  1 or 2 in the Z order
build overviews..
All worked out well..
The white hole you see here is a military area where they do not want to be display....in the 2009, there is a full of naip all over the state....
