Convert a floating type raster to Integer
34704
6
12-18-2017 01:28 PM
DevinUnderwood2
I am using the Raster Calculator Tool to change my raster from a float to a integer so I can eventually change run Raster to Polygon (need to integer raster input)
I ran the tool several times using the following expression)but my result is still a float.
"pointden100ft" * 1000000000
The expression is very easy as I consulted the following ESRI tips
https://support.esri.com/en/technical-article/000012554
Any ideas what is causing the issue ?
Tags (1)
SteveKopp
Even though you have moved the decimal point, the values in the dataset are still stored as FLOAT. To change the dataset to INTEGER, you need to use the INT tool.  So if you're doing this in raster calculator, just add INT (<your express here>)
SteveKopp
curtvprice
MVP Esteemed Contributor
Just to be clear, Raster Calculator is case sensitive with function names, it needs to be Int("input raster").
SteveKopp
Yes good point, just using full caps for emphasis.
menghui99
Hi all, I have tried doing it a few times but the result raster still has "unsigned char" pixel type. This is my expressions:
Int("210113_FullTerrain_V7_UpdatetoExistingInvertLevel.tif" *0 ) or
Int("210113_FullTerrain_V7_UpdatetoExistingInvertLevel.tif" ) *0
Any problem here?
DevinUnderwood2
Perfect, that is what I needed. It works now .
Thank you.
DevinUnderwood2
Thanks, I used the Raster Calculator syntax helper to double click the Int option to correctly complete the expression.
