Default Mosaic Operator - Minimum
2714
02-25-2016 11:21 AM
NicholasVoss
New Contributor II
I have created a mosaic dataset that has overlapping 4-band aerial imagery with different resolutions.  If have set that mosaic dataset to use the "Min" Default Mosaic Operator.  Based on the documentation, this should display the non-white pixels, given the white pixels are 255,255,255,255.  I have also tested with setting a "no data" value for pixels that are value 255 for all 4 bands.   I've found, as I zoom in, the min operator appears to work as expected, so what may be causing it not to work at the higher zoom scales?
I've included a few attachments to demonstrate this issue.
PeterBecker
The issue is related to the 'CellSizeTollerance Factor'. The default is 0.8. It essentially means that if imagery has differing resolution and factor between the pixel sizes is > than this value, the system will pick one (the nearest to the current display). In this case you have pixel sizes that are a factor of 2x different. If you change this value to 2.5 and then re-run 'Calculate Visible Items' the issue should go away. The system will then assume that you want to see these differing resolution image as the same time.
Its not clear to me why you wish to use 'Minimum' as a mosaic method in this case. It is likly to cause strange artifacts in the image as for overlapping pixels the pixels with the lowest value will be selected. As the images have different resolutions you will get a mix of resolutions back, also darker objects (eg shadow) get a preference to lighter object.
You should be able to just define the mosaic method as first.
What you will want to do is still remove the white. There are various options
1) Just define white as NoData - Works but not optimum and if the original data is compressed then you may get compression artifacts at the edges
2)  If there is overlap between the images (which I assume is the case) then even better is to 'Recompute the footprints' with a small 'Shrink Distance' and set 'Maintain sheet edges' on. What should happen is that the footprints will be redefined to exclude the white areas. You can then set in default properties: 'Always clip to footprint' to Yes, and 'Footprints may contain NoData'  to No. The system will then clip the images based on the footprints.
3) You can use the 'Build Seamlines' tools. These will perform an analysis of the overlapping areas and generate seamlines along which the image can be clipped and also blended to hide the transition.
Once you have got this working at the larger scales you will probably want to regenerate the overviews.
DarrenWiens2
MVP Honored Contributor
Not sure if you've zoomed out far enough to be using overviews, but you may try Build Overviews to renew those overviews to use the correct mosaic operator.
PeterBecker
NicholasVoss
New Contributor II
Peter - Thank you!  This was very helpful.
