Problem: One of the ten images went missing from the mosaic when I opened up the file again after closing ArcMap.
The missing image(#9) is at the very bottom left corner of the mosaic. Below are before and after images for comparison. It happens that the top image is cut off at the top but it's the bottom left corner of the images I'm referring to.
When I examined the properties of image # 9, I noticed that the extent had changed so it's gone to another part of the world at: left -774681510.957742; right 765587077.215732; top 1002030686.2084 and bottom 992902249.935427. I reloaded the original links to image 9 several times but that didn't do anything to change the new extent numbers.
Next I removed image 9 entirely and replaced it with a new copy of that image with a different name. After I added the links, the new image 9 was in its proper place in the mosaic.
However, after I closed and reopened the file with new image 9, the NEW image was missing, just a before. New #9's properties indicate that it now has a different extent in some other part of the world.
Can you help me figure out what is happening to change the image extent when I close and reopen the mosaic file?
This extent change did happen once before with a previous mosaic. I never had to deal with that though because I made another mosaic. Thanks.
