mosaic dataset
533
12-07-2017 11:37 PM
MANESK
I've created a Mosaic dataset..After Defining No Data value as  "0" to the all Bands i have the output attached in .Png Format...Still i've to fill the gaps between the images and eliminate the artifacts... How can i do it.... i tried with the Function for Raster Calculator posted in previous threads
Con(IsNull("raster"), FocalStatistics("raster", NbrRectangle(5,5, "CELL"), "MEAN"), "raster")..
But Still i've the problem.... Pls provide valuable suggestions....
CodyBenkelman
It's hard to tell for sure, but it appears the pixel values in those "slivers" are not 0, therefore not being flagged as NoData.
There are 2 ways to manage NoData (with a few configuration options) - we typically recommend NOT to define a NoData value, but instead define Footprints (perhaps shrinking them by a few pixels distance) and then in Mosaic Dataset properties, turn on Clip to Footprints? = Yes
See background here Source mosaic datasets—Standard Workflow_Creating Mosaic Datasets | ArcGIS  and see the section "Footprints and NoData"
