mosaic raster with transparency
3746
04-08-2015 12:37 PM
davidmetzler
Greetings all.
its been some time since I have done some mosaicing in ArcMap and I am finding some difficulty. I have 6 rasters that I would like to merge into one file so I can serve them out as one map using geoserver. They are currently geotiffs or png's. The maps are at angles relative to one another so I am running into issues with null values.
at places where the images overlap I cannot get a good result. either its white, black, or the wrong values. since the inputs are png there is  an alpha of 0 or 255. can someone help me merge them together?
attached is what I am getting and what I would like.
Thanks!
this is the result
this is what I would like
Tags (3)
BruceBurwell
Dave
One thing that I have found that is easy is to add the mask function to the dataset. You can do this using the image analyst toolbar. Of course, I am assuming that the black padding is all 0 values.
Hope this helps.
Bruce
