Hi Gregor,
I just tried this solution and does not work for the mesh nor the point cloud. Both float way above.
I used these coord systems: image: GCS WGS 1984, EGM96 and for Project: WGS 1984 UTM Zone 31N, EGM96.
(1) Should I be using Above Ellipsoid and leaving the Geoid Height at 0??
(2) I am not using a local terrain file just the defaults. I am looking for one to use, but the instructions above do not mention this. Should I also be using one?
(3) Images are from DGI Mavic with altitudes in centimeters how do I fix this with D2M?
(4) Further, I have all project units set to meters, but when I mouse over they display feet units are displayed. I cleared the cache but no change.
Please let me know what you recommend for the 4 items above. Thanks,
L.
