Hi Cody,
I did apply the raster function to the MD with the smoothing the only option. I did this because it was indicated in the user documentation that was packaged with the tool download.
"Vector Contours
If vector format smoothed contours are required, they can be created in two steps. First, use the contour ‘Smoothing only’ mode (see below) and either export the resulting DEM as a raster saved to disk, or save a raster layer that includes the ‘Smoothing only’ mode. Then, use the Contour function available in ArcGIS Spatial Analyst to generate the vector contours, using the smoothed DEM or raster layer as input."
I did also try it with the smoothing option off.
Also, I looked at the raster contour function. It is very nice. I like how it adjusts the contour interval on the fly. But I have two problems with it.
1) No labels. I see the suggestion is to create spot heights...
2) Not sure how I am going to host this - I am waiting to hear if we have access to ArcGIS sever with image extension for the project.
Forest
