Install and setup Java SDK with InteliJIDEA
1489
11-23-2017 10:55 PM
IonutAlixandroae4
I am a little bit confused about the steps to install and configure Java SDK with InteliJIDEA IDE and not with Eclipse.
Can you guys help me with that?
Ionut
Markvan_Wyk
If you're happy to use Gradle...
It's pretty simple. Create New Project > Gradle Project ...
Then edit your build.gradle and place sources as per example below:
Develop your first map app with Gradle—ArcGIS Runtime SDK for Java | ArcGIS for Developers
Add a "run configuration" via the Gradle Docker. Select your project and add a task "run"
Should be really simple. Took me 5 minutes.
Gradle / IntelliJ Project here: Gradle - Help | IntelliJ IDEA
Markvan_Wyk
IonutAlixandroae4
Hi Mark,
I`ll test it out and let you know !
Thanks a lot!
Regards,
Ionut
IonutAlixandroae4
It worked! Thanks a lot.
I didn`t had to download the SDK, the build.gradle took care of it
Thanks,Ionut
